Loudest 12" for around $100. CVR12 or ????
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 160
Whats the loudest 12" subwoofer (just bass not sound quality) for around $100 or in the price range of the CVR12? Is a CVR12 the loudest for that price?
Thanks
Brad
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1704
maybe a AA assassin, their supposed to be better than the atlas and the atlas can hold its own spl wise with the cvr, while using less power.
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 164
What about the TYPE R alpine (more but is it louder)?
Username: Redliner
Wilmington, Ma
Post Number: 1646
i think the typr r and cvr are close in spl btut he r sounds better and i heard the assassin wont get as loud as a cvr but will sound better
Username: Dustin3
Tigard, Or U.S.
Post Number: 981
^^ cvr is better in my opinion. they get louder. but the r has better sq, but since you want spl, get a cvr.
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 166
What box do you think would be the best for a CVR 12" with a good amp pushing it in the back of a trunk? Should I get a big sealed or a big ported box and where should the sub (or port) be faced?
Thanks
Brad
Username: Young_james
Post Number: 1365
ported built to specs and face it wherever it sounds the loudest
Username: Dustin3
Tigard, Or U.S.
Post Number: 985
you can find the specs on kicker.com i beleive
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 168
Do you guys think the Audiobahn Aw1206T would be louder? Where do you the CVR12 would fall in this catagory as loud bass not sound quality? Out of these audiobahns are these in order from loudest to worst and where would the CVR go inbetween? These are my prices, most are not on ebay. What would be the best for the money and it will have enough amp. I can have a box just big enough for 2 12"'s in a small ported box or 1 big ported box. I want to only spend $160 on subs but will spend more if I have too. What benifits would the CVR's have over the audiobahn?
Comp 12" $45.... 40-45oz
CVR12 $75....... 45-50oz
Dub1200 $80 120oz
aw1200N $90 120oz
aw1206t flame $115 120oz
AWES12P eternal $170 180oz
aw1208t flame $163 260oz
AWIS12P immortal $210 200oz
Username: Ctmike
Ct.
Post Number: 373
if all you want is spl, then get the immortal. i really hate recommending audiobahn anything cause they are sh$tty but it'll get loud.
Username: Sw9152
Michigan
Post Number: 495
what about 15" subs, will they not fit?
you could get a 12" L7 off ebay for around 150-160.
Username: Sw9152
Michigan
Post Number: 496
have not heard either but the aw1208t looks louder than the immortal IMO.
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 169
What would the CVR be as loud as because I guess I will take the sound quality if it will get loud?
Thanks
brad
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 170
Would this box be good for the CVR 12"? http://cgi.ebay.com/SINGLE-12-SLOT-PORTED-VENTED-SUB-BOX-3-4-MDF-NEW_W0QQitemZ97 20421164QQcategoryZ50568QQrdZ1QQcmdZViewItem
cvr specs below for the SPL/Deep Bass
2.25 ft3 (63.7 L) + port displacement
3" x 12.5" port, 20.5" long
(7.6cm x 31.8cm port, 52.1cm long)
Power Handling = 300W RMS
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6817
why not get a MOFO, it has like a 300oz magnet on it since ur comparing magnets
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 171
I just put that in there to separate the audiobahns which are compared by magnets.
thanks
Username: Extrmndor3
Chicago, Ill Us
Post Number: 569
yeah the aw1206t will be louder u can hit 140 wit 800 rms and it wil lbe like 400 watts rms to each sub that was my fisrt system it was wit two sonys p5 amps and i got lucky to hit that number i htink it was because i builded the enclousure for spl oh the spl on the aw1206t is ok go to cardiscoutstereos.com for the aw1208t for like 110 for the 12 but forget about sq u will get loud wit those
Username: Opie_har
Somewhere, One of them USA
Post Number: 200
I have one aw1208t and that thing gets extremly loud, its being powered by an audiobahn a2200hct amp in a 2.5 cubic foot slot ported box. Not much sq, but a ton of spl. Just my $.02
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 172
Where on that website do I go?
Chicago, Ill Us
Post Number: 572
yeah bro i dont know why people hate audiobahn so much it get so loud and i dont know why but those aw line are easy to get them loud
Chicago, Ill Us
Post Number: 573
aw1208t for 110 just search for those subs oh u will be happy bro even they sell crappy brands their shipin and customer service is great i luv their shippin freakin fast
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 175
Okay, Thanks. I just cant find them??? Thanks for the help!
thanks
Chicago, Ill Us
Post Number: 574
cardiscountstereos.com
08t 129$$http://cardiscountstereos.com/catalog%20page.asp?Product+%23=AW1208T
and my old aw06t i luv them
99$$ they will get louder than cvr and r but less sq but not by much .
http://cardiscountstereos.com/catalog%20page.asp?Product+%23=AW1206T
hey do not buy other line of audiobahns subs execpt the aw and ethernals and imortals truste me dude
Chicago, Ill Us
Post Number: 575
happy now bro???
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 176
Yeah, earlier on ebay they had the Aw1208T for $150 total I think and the 06 for 115 total.
They either just ended or took them off.
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 177
thanks a lot for the help!
Chicago, Ill Us
Post Number: 579
man those fakin aw series are one of my favorites first cuz was my firstlouderr than 135 db wit 400 rms to each
and freakin cheap plus they look cool dude im gonn asave a little and buy the aw 08tfor spl or im gonna buy another pair of the 06t and im gonna make a wall on my truck
Username: Bradgman
GAlVeStoN, Tx Usa
Post Number: 181
hahah! That will be stupid loud!!
Chicago, Ill Us
Post Number: 582
hey bro why u dont just buy 4 12 phoenixgold octane r they are pretty much like the cvr but alot less im talkin to the z rated ones is like 50 each for the 12 at ikesound.com but the audiobahns will be louder hey bro dont buy the 08t if ur usin it for daily drivers cuz it has no sq is just a spl sub but if u want loudness go wit that or buy the 06t and u will have a much diference sq than the 08t but u will lose spl
