$650 to spend
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2089
for just sub and amp .. either 1 or 2 subs .. gotta be 12's though ... i want more spl but cant sound like $hit .. any suggestions ?
Post Number: 2091
oh yeah the subs will be going in 1.25 cuft sealed boxes
Username: Rovin
Trinidad & T...
Post Number: 7605
here's a sweet combo
1 12" IDmax 2ohms dvc version ($300) with
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965
Post Number: 2092
i already get moderate blinking with 600 watts ... you think i could handle that amp with the big 3 and a yellowtop
Post Number: 2095
which would get louder on 800 watts ? 12'' cvx or 2 12'' cvr's ?
Username: Rovin
Trinidad & T...
Post Number: 7608
well from what i read a idmax olny needs like 700/800 mostly 2 perform full so u may not need 2 crank it up high .
I had that amp on my lil 1500cc engine & 80A alt & it worked perfectly on my 2 Rs .
https://www.ecoustics.com/electronics/forum/car-audio/189456.html
Username: Rovin
Trinidad & T...
Post Number: 7610
2 cvrs 4ohms dvc version is also a good choice with same MB amp ...
Post Number: 2098
yep rovin .. that is a very possible setup right now
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1701
you could also consider 2 AAarsenal's off that amp.
http://www.ascendantaudio.com/arsenal12specs.html
