My amp won't work---help me!
Username: Jsin
I got a 2000w 4 channel amp I just bought. However, It's getting power (lights up) and input signal (tested by hooking directly to speakers) But no signal coming out of the channels. It has a bass boost remote, but the remote LED doesn't light up when the amp is on. Also the power light next to the protect led isn't coming on. I redid my grounds, what's going on?
Username: Snopro4ever
do you have your remote connected? even if you have your main power wire connected, the remote has to be there or it wont turn the amp on.
Username: Jsin
I haven't had it connected at start-up. I'll try that right quick----thanks
Username: Jsin
tried it.... still no light at power or on remote, but amp lights up
