Fan for Amplifier?
Username: Stnorris
Post Number: 13
I want to get a 12 volt fan or some kind of fan for my amplifier. The amp is solid on the outside and doesnt have an internal fan. I need something to keep my amp cool. Its in my trunk.
Username: Dustin3
Tigard, Or U.S.
Post Number: 936
then get a fan... find one and post it here, you really cant go wrong with any sort of fan because each one does its job.
Username: Stnorris
Post Number: 16
Anyone know of any fans that would do a good job keeping my amp from getting so hot so quick. The amp gets really hot in a short amount of time because i have it bridged.
http://cgi.ebay.com/HOT-SONY-XPLOD-1200w-2-CHANNEL-CAR-AMP-AUDIO-AMPLIFIER_W0QQi temZ9714456885QQcategoryZ39738QQrdZ1QQcmdZViewItem
Theres the amp. Anyone know what kind of fan i need either? I dont know what i should get. HELP! give me a link if you have something good.
Username: Van_man
Boston, MA
Post Number: 97
get one a radio (S)hack for ~15 bucks wire it with a relay and a thermo swith to turn it on and off.. DO NOT use the rem to control it
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 76
Just wondering, since the rem turns the amp on and off, why wouldn't you use the rem to control it?
Username: Van_man
Boston, MA
Post Number: 105
The fan NEEDS 12 volt to run.. The REM outputs ~ 5 volts. ok?
