I have a question about AMP . plz
Username: Night_mirage
AmmanJordan
Post Number: 252
What is this mean ..
1200 @ 1ohm
600 @ 2 ohm
300 @ 4 ohm
is it mean my amplifier gives the sub just 300 RMS
but my sub is 750 RMS DVC 4ohm . 12 cvx ..
and if i get cvx DVC 2ohm .. is it better or what ..
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6646
since you have a 4ohm sub, you can wire it in parallel like this
And you would get 600rms from your amp, if you where to get the 2ohm version, you would wire it the same way but it would produce a 1ohm load, and would send your sub 1200rms
AmmanJordan
Post Number: 255
wooow its good chauncy . thanks
its the first time i saw this kind of wiring .
and i will get 2 ohm
