The REaudio and mx/// mt
Username: Kicker101
Alberta
Post Number: 34
Is the MX or MT better?? and do they even make the mx anymore or sumthin..Wich reaudio is best all together like including all there subs..??
Username: Extrmndor3
Chicago, Ill Us
Post Number: 509
the re audio mt is re audio best spl machine and the mx it will be a lower version of their new xxx
Username: Kicker101
Alberta
Post Number: 35
so the best sub alltogether is MT??
Username: Mr_kebo
Albertville, Al USA
Post Number: 282
For purely spl yes. As a Daily use sub i wouldnt recommend it.
Username: Kicker101
Alberta
Post Number: 38
what is spl anyway
Username: Basshead86
Ocala, FL USA
Post Number: 2822
here we go again. lol
SPL is how loud the bass is. Sound Pressure Level
Username: Kicker101
Alberta
Post Number: 39
ha i know ima rookie but thanks
i think ill get the MT cause i want as much bass as i can get...
and ill tos it in ith an audiobaun amp
does any one know how many wtts the 12" MT is?
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 718
it can handle bookoo wattage, i know of someone with 3600 rms goin to it. but u can put more than that to it for burps at comps.
u do realize that i prolly wont sound that good?... right?
and ur gonna need something better than an audiobahn amp for it.
Username: Kicker101
Alberta
Post Number: 43
thats what ppl keep sayin but wont a top a tha line audiobahn amp work?? u prob one thats hated audiobahn right ha
Post Number: 721
well i wont buy audiobahn, but i dont come on here bashin stuff. im just sayin, the MT is a KILLER sub and i dont think audiobahn has anything with enuff TRUE power to push it.
Username: Dustin3
Tigard, Or U.S.
Post Number: 853
it doesnt make sense anyways. if you going to but a 1000 dollar sub, you need a good amp to push it. not some audiobahn amp. not for such a powerful sub atleast.
Username: Kicker101
Alberta
Post Number: 50
yeah good point
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 615
orion 2500d
kicker 2500.1
Rockford Fostgate T1000bd
If Re acutaull makes this
72.2 specs at 4 ohm 72x1 then magically 4000x@ 2ohms
any higher end Zapco amp
all these be prepared to spend 1000$ easially on the amp an electrical upgrades
ANy lanzar (where lucas been anyway)...syke j/k dont listen to me Killer....LOL
sony xm-sd61x.....LOL...LMAO.....stfu
Post Number: 728
the MT isnt a 1000 dollar sub. they range in price from about 450 to 550.
i know RE makes a 36.1 amp. it does 1800 @ 1ohm. i actually found one an ebay and bought it. i called RE also to confirm it before i bought it. its sweet. supposedly only about 3 were ever made.
Post Number: 621
I think sum1 else bought a 36.1 amp 2 wuz it u....Johhny an only u.....but johnny u werent happy with it were u....
the new 2006 car audio directory in Car Audio Magazine has 3 re amps listed....none of wich are a 12.1..
Post Number: 734
yeah it was me, i wasnt that impressed with the amp. i had an orion 1200D before that. i think the 1200D performed better only cuz of the intelliQ function, which helped put out more power at a certain freq range, better than wut a LPF could do. it works the best at wut ur box is tuned to.
but its such a rare amp that i dont really want to sell it.
Post Number: 735
btw the amp still slams my sub. i guess i was just expecting much more from it.
