Generic dynamat??
Username: Quig
Pittsburgh, Pa Us
Post Number: 71
i really dont feel like payin the rediculaous amount of money and waiting for slow etronics to ship some dynamat, can someone tell me what its made out of, never seen it personally, and has anyone ever tried anything else on the inside of there trunk lid like a type of foam or something to stop ratteling? any tips would be helpful, thanks.
Username: Van_man
Post Number: 52
Roofing material called ice and water block. Sticky on one side. you can get at roofing supply companies..
Username: Langless28
Boston, MA
Post Number: 518
when that stuff gets hot, specially inside a car on a hot day, it smells so bad. just a heads up
Username: Quig
Pittsburgh, Pa Us
Post Number: 72
smells like what, and will it alwasy smell like that, just the trunk or will it leak inside the car?
Username: Van_man
Post Number: 53
didnt know that....
Username: Quig
Pittsburgh, Pa Us
Post Number: 73
i am googling for it i cant seem to find it....
Boston, MA
Post Number: 520
i wouldnt reccomend using it, if you do something, do it right the first time. but their are alternatives to dynamat, theirs edead and some ohter spray on stuff and its too late to think of anything else. if you want to try to use the ice and water block. put some strips on the trunk of your car. if the smell doesnt bother you, then use it. i think i read somewhere it gives off bad fumes too. not 100% sure on that tho
Username: Van_man
Boston, MA
Post Number: 54
http://www.graceathome.com/pages/roofingprod3.htm?WT.srch=1
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 325
Other than dynamat, I've heard of R-blox, Edead, Fatmat, Dead Skin, RF sound deadener, and Cascade...
Username: Alteraudiousa
Concord
Post Number: 648
peel and seal, you can get it from Lowes or most home improvement places. Same stuff as edead. And if you smell something you either smell the asphalt base or butyl rubber base.
Username: Nypdlapd
Post Number: 292
Use the foam in the can or THE PINK THINGY THATS SOUNDPROOFS ROOMS JUST USE ADHESIVE!!
Username: Nypdlapd
Post Number: 293
UploadUpload
Username: Nypdlapd
Post Number: 294
the pink thingy would be best because thats the soundproofing model!!
Username: Yukhui
Post Number: 326
What would i use to soundproof my room? My neighbors always complain about my bass, LOL!
Username: Nypdlapd
Post Number: 296
NO USE IT FOR UR CAR MY FRIEND DID THATS STOPED MOST OF THE RATTLING!!
Username: Nypdlapd
Post Number: 297
Username: Nypdlapd
Post Number: 298
also made it sound louder becuase it blocked outside sounds!!
