New member Username: B_sonPost Number: 1 Registered: Apr-06 | what amp should i get and how should i wire them! Boston Acoustics G510-44 10" Subwoofer Size 10" Impedance 4 ohms Dual Voice Coil Yes Peak Power Handling 900 watts approx. RMS Power Handling 450 watts |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 920 Registered: Jul-05 | Jl 1000/1 rockford t10001 pretty much anything that has 1000w rms @ 1 ohm or @ 4 ohm. |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2562 Registered: Sep-04 | wire them in paralel or series parallel. parallel will get you a 1 ohm load and series parallel with get you a 4 ohm load. www.rockfordfosgate.com has a woofer wiring wizard that will help you out. just put in 2 woofers and dual 4 ohm coils. also, id really like to hear your review when you get them going! |
Silver Member Username: Extrmndor3Chicago, Ill Us Post Number: 518 Registered: Feb-06 | hey try those g5 wit a passive radiator in a smal sealed box wit the radiator facin in the back and u willhear better and louder sound that a ported |
Gold Member Username: James1115Ct Post Number: 5642 Registered: Dec-04 | those g5's are very very nice subs I am very impressed with their bottom end, sq and output capabilities. you should be very happy. |
Gold Member Username: James1115Ct Post Number: 5643 Registered: Dec-04 | jake's idea of the 1000/1 is a great idea |
Silver Member Username: JakeyplaysbassSt. Louis, MO Post Number: 922 Registered: Jul-05 | if you do a sealed box this is another good amp choice. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=590 its alot of money but its one of the best amps out. |
Gold Member Username: James1115Ct Post Number: 5660 Registered: Dec-04 | it sure is |
