Hey B i want to no sumthing bout treo
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 89
i have two tsx 12.44 and i wuz wondering if uve ever had urs blow
how much power should i put on it and for it not to blow
Username: Logan__tille
Post Number: 67
i taklked to treo and it said its safe to put double there rated power
Post Number: 68
i talked to treo and they said it was safe to give them double their rated power
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 931
i would say around 500-1000 would be ok. just because you can put alot of power to them doesnt mean you have to.
Username: B101
Queen City, NC USA
Post Number: 2508
always remember ur chargin system 1st, its no persons fault if u blow them. I never had any problems to date! Like Jake said, they will get super loud with 500rms... but with 1000 they get way louder. :-)
Username: Kyle_lowe
Post Number: 31
how loud are you guys hitting with your tsx's
Post Number: 90
thnx im gunna look for an alternator
