Ported vs. Enclosed
Username: Kicker101
Alberta
Post Number: 41
I know its an on going battle but wich is better???
i have a 12" 800wtt clarion and its in a big ported box and it pounds and shakes and rattles and sounds great.. Its sounds better than my 2 12" jl's in an enclosed box ... So which do you think is better???? Heres my boxes PORTED VS> ENCLOSED!!!! Upload
Username: Juliob
Santo DomingoDominican Re...
Post Number: 437
ported=spl enclosed= SQ so you figure it out
Username: Gravestream
The guy above is wrong about that, It depends a lot on the vehicle. Anything with an open cab I.E. suv's hatchbacks trucks, sound better with ported boxes because their is no air restriction, In a trunk your better off sealed. Bandpass boxes just suck, and are really just designed for looks. If those JL's were in a ported box you've find out shortly why JL makes better subs the Clarion.
Username: James1115
Ct
Post Number: 5649
agreed^
Username: Yayo
thanks for that
Username: Ton
Post Number: 59
i always tought it otherwise, that ported boxes are better with trunk cars because trunk are more seal so difficult that the bass come into the cabin and because ported are louder it will sound be better. and sealed boxes are better with hatchbacks, SUV's etc. mmmm something new for me.
Username: Rovin
Trinidad & T...
Post Number: 7433
take a read
http://www.diysubwoofers.org/ ......
Username: John_wash
Nashville, Tennessee
Post Number: 231
so u guys are telling me that all this time i've be tryna design a good ported box that there really is no use because im putting it in a trunk of a car.
Username: James1115
Ct
Post Number: 5682
no ported boxes in trunks are fine.
Username: Juliob
Post Number: 473
i wasn't talking about ported or sealed in hatchback or whatever, i'm just saying the difference between sealed and ported boxes.
Username: James1115
Ct
Post Number: 5684
I kn ow Julio but if a ported box is tuned close enough to the FS of the sub it has more control then in a sealed enclosure therefore retaining better sq in ported then that of sealed. the higher you tune the enclosure the more you steer away from sq and more toward spl.
Username: John_wash
Post Number: 232
whats a good tuning freq. where i can hit high notes well and the lows well also
Username: James1115
Ct
Post Number: 5690
what sub do you have?
Username: Rovin
Trinidad & T...
Post Number: 7442
like James just said in his above post - look @ the spec sheet of ur sub & tune just above the Fs , ex if Fs = 28hz then u can do 30 or even up to 34/35hz but u will lose alot of SQ & it will sound boomy ,personally i like around 32/33hz its IMO a nice balance of SQ & SPL depending on it the sub though .....
Username: John_wash
Post Number: 233
kicker cvr15 freq=20.8
Username: James1115
Ct
Post Number: 5692
so anything tuned from 25-32 would sound nice with that sub
