Bronze Member Username: SeriusMiami, FL USA Post Number: 25 Registered: Feb-06 | whats a good wiring brand ive been lookin at gettin a 0 guage from: -stinger -Elemental designs -tsunami and whats a better sound damping -eDead v1SE or -second skin audio or save up alot of money and get dynamat?? thanks..! |
Silver Member Username: AdddisorderPost Number: 138 Registered: Jan-06 | not to sure which is better but stinger is good, ebay is a cheap place for wire |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 817 Registered: Oct-05 | http://www.knukonceptz.com/ for all wiring edead v1se |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 2787 Registered: Aug-05 | stinger is what i have.... a lot of people think knukoncepz is really good...i agree. and dynamat is more expensive for a reason!!!!!!!!!!!!!!!!!!!!! i will not get into that one..lol but sound deadener is sound deadener. |
Bronze Member Username: SeriusMiami, FL USA Post Number: 26 Registered: Feb-06 | ok i have another question ok if i put a 4 guage kit on a RE 12.1 would it hurt? ill upgrade later on but im short on cash. also the 4 guage amp kit from knukoncpetz(http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4) says: -One 5 Meter Klarity Kable Blue OFC RCA Cable with Built in Turn On lead what happens if i put a 18 guage remote turn on lead aside from that. would they interfere cuz i wanna run it to a toggle switch. thanks agian |
Bronze Member Username: SeriusMiami, FL USA Post Number: 27 Registered: Feb-06 | bump |
Bronze Member Username: SeriusMiami, FL USA Post Number: 31 Registered: Feb-06 | can anyone help me? |
Silver Member Username: Matt12490Benicia, California USA Post Number: 719 Registered: May-05 | I think second skin is the best out of those, but it is also very expensive! The 4 gauge kit on that amp wont hurt it. I'm not sure about your second question tho, sorry. |
Bronze Member Username: SeriusMiami, FL USA Post Number: 34 Registered: Feb-06 | its ok i figured it out already thanks agian tho... |
Bronze Member Username: SeriusMiami, FL USA Post Number: 35 Registered: Feb-06 | ok i also posted the same thing on the AMP section and he tells me that 4 guage is not enough??? https://www.ecoustics.com/electronics/forum/car-audio/217053.html |
