Bronze Member Username: Alexv3305
Tavernier,
FL
United States
Post Number: 44 Registered: Mar-06
Posted on What amp do you all prefer? - Soundstream PCA3500D - Rockford Fosgate T30001BD - Orion HCCA-D5000 I just need a powerhouse and I'm going for SPL. What amp should be most reliable and produce legit power ratings? |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 808 Registered: Mar-04
Posted on they'll all do what they're rated for if you can keep the voltage at an acceptable level. I'd say --- Orion RF SS FWIW - in that price range I'd suggest looking into the Lanzar Opti4000D. Better than 4kw at 1 ohm and a step up in quality from the SS PCA series. |
