Wiring??
Username: Drivingreckless
Nuthingsville, Florida United state...
Post Number: 65
sum sites say u can wire 2 dvc 4 ohm subs to 2 ohms and others say 1 ohm but wen i did the math:
1/r=1/4+1/4
1/r=2/4
r=4/2
r=2 ohm
or would it be since its dual voice coil??
1/r=1/4+1/4+1/4+1/4
1/r=4/4
r=4/4
r=1 ohm
Username: Goatin
U.S.A
Post Number: 769
Dude what are you trying to figure out?
What sub/s do you have or plan on getting.
Post Number: 66
i have two treo tsx 12.44 dvc 4 ohms each voice coil i want to wire thm to 2 ohms and need to no if it is possible???
Username: Goatin
U.S.A
Post Number: 770
if you want to wire them individualy
