I need an amp
Username: Eseesai
Post Number: 35
i need an amp to power 2 MA Audios that are a single voice coil 4ohms and put out like 250rms i need an amp to power them that is not over 200bucks any suggestion?
Username: Dustin3
Tigard, Or U.S.
Post Number: 809
you want to find an amp that puts out 500 watts at 2 ohms. and for that price you need to stick with viper, audiobahn, hifonics, mtx or others. find an amp that puts out 500 @ 2 ohms
Username: Nruzicka
Post Number: 20
dude i just put a alpine m350 amp in my jeep and it pounds like no other
350rms 700 max but it sounds like more than it is rated at.
Username: Dustin3
Tigard, Or U.S.
Post Number: 812
ok
Username: Eseesai
Post Number: 38
oh ok thanks and what do u recommend it my max budget was close to 300bucks?
Username: Rovin
Trinidad & T...
Post Number: 7329
JL 500/1 ....
Username: Johnny619
San Diego, CA
Post Number: 114
I got a JL 500/1. 300 plus shippin.
Username: Ctmike
Ct.
Post Number: 255
$219.99 with free shipping
http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=x600%5F1
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6485
^^^^GET THAT
Username: Gage
Post Number: 185
yeah thats a nice amp
Username: Eseesai
Post Number: 39
yeah thats a great amp but the thing is that i know that the subs arent that great but i just need a amp that would power them good but thanks thats just too powerful fot those subs or atleast i think so what do u guys think
Post Number: 6491
They will be fine
Username: Eseesai
Post Number: 40
oh ok then what else would u guys recommend?
Username: Ctmike
Ct.
Post Number: 258
i'd say get the pg amp. it's a great amp and with your budget it'll be hard to find an amp as good as that, unless you get lucky and find something on ebay.
Username: Rayadicto
Post Number: 7
i have a boss c700 it is a 1200 watt amp and i am powering two 12" E types with it right now and it hits hard, i can sell and ship for 150 this sucker hit HARD!
Username: Gkaste
Post Number: 14
Check out the Aura 2x150 at partsexpress.com. It will put out 540watts rms x1. Thats a little over your subs reccomended rms, but it will be just fine.
Username: Gkaste
Post Number: 15
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=269-162
Username: Ctmike
Ct.
Post Number: 260
i don't know bout that one^^ specs say 450 x 1 @ 4ohm, then 540 x 1 @ 4ohm. i think the 540 is there "peak", not rms. and who the h&ll ever heard of aura, i haven't till now.
Username: Gkaste
Post Number: 19
Aura makes some very nice equipment. Maybe you havent heard of them, but best buy dosent carry them either. Check the specs on their website if you are confused, they have a nicer spec sheet.
Username: Eseesai
Post Number: 41
thats a very nice amp but what out of the amps recommened is a bit better?
Username: Ctmike
Ct.
Post Number: 279
i've never heard of the aura but can tell from experience with them the pg xenon line is well worth it. actually rated and full load from 4-1ohms.
Username: Gkaste
Post Number: 24
Go for the Aura, its top quality and you sure cant beat the price!
