OT: Head unit size question.
Username: Goatin
U.S.A
Post Number: 754
I have a Pioneer 860MP HU.
I had a sony explod Old School HU.
The question is : My HU mounting bracket thing (the plastic piece that holds your HU in place) it fit my explod perfectly and I decided to use it Temporarily because my new pioneer HU does not fit flush like my sony did because of a 1/16 - 1\32 gap all the way around my HU.
So I thought I would go to my local circut city and buy a mounting plate with a smaller hole and the sales man said that they only sold one size of HU mounting brackets and he said to just spread out the tabs more, So I did and now it is more firmly in place but there is still that anoying gap.
So was he right or just a typical idiot?
Username: Goatin
U.S.A
Post Number: 756
Username: Jmloughrey
Farmington, CT
Post Number: 1484
Are you talking about the cage that the headunit slides into and locks in place?
Username: Goatin
U.S.A
Post Number: 757
Yes if that is what it is called.
My HU sinks back in because the hole is too large.
Username: Goatin
U.S.A
Post Number: 758
Username: Pratcell
Same problem:
Where can I find out what the error
messages stand for? I try to burn a Video
CD and it goes all the way through and I
get an error message# =[IM06009] Then it
just says cancelled. How do I know what the
problem it? Can anyone help? Thank you.
Username: Goatin
U.S.A
Post Number: 759
860MP's does not play videos and or your CD is the wrong format.
I just want to know if they make a HU mount with a smaller hole so that my HU will fit flush?
Username: Goatin
U.S.A
Post Number: 765
Here are some Pics if you can see.
Username: Goatin
U.S.A
Post Number: 766
Is that normal ^^ ?
