Treo ssi 12 vs. rl-p12
Username: Kyle_lowe
Post Number: 11
overall which would sound better. the price is about $20 difference with the treo costing more. if the treo is better is it worth the extra $20?
Username: B101
Queen City, NC USA
Post Number: 2326
the SSI is very hard sub to even compare too... I only have experience with those not the RL-P.. Both are very good subs... I would have to choose the SSI.
Username: Basshead86
Ocala, FL USA
Post Number: 2798
from Soundsplinter's website on the Rl-p:
optimized for small to moderately sized enclosures with input power levels between 400 and 1000 watts (conservatively rated at 500 watt RMS).
the Treo SSi is conservatively rated at 750wRMS....and will take 1000wRMS ALL DAY LONG...if not more:-)
.....there is your 20 dollars. lol
Username: Kyle_lowe
Post Number: 13
would the treo sound alright with 800w?
Ocala, FL USA
Post Number: 2802
it would get loud...but that is moderately powered....a beefy moderate though...lol
it will definitely ge down with 800w.
what kind of charging system do you have?
Username: Kyle_lowe
Post Number: 14
charging system?
Username: B101
Queen City, NC USA
Post Number: 2331
yea charging system...
what size alternator? have your upgrade to a HO alternator? Have you upgraded the BIG3 wires?? What size/gauge wires you have runing to the back??
Those would be considered your charging system..
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2489
alternator? big 3 upgrade? power and ground wires? batteries? caps?...
Ocala, FL USA
Post Number: 2803
how big is your stock alternator?
how do you think you are going to power a sub that needs 700-800w RMS with just a stock alternator?
Post Number: 2490
"B"eat me to it lol
Ocala, FL USA
Post Number: 2804
me too. lol
Username: B101
Queen City, NC USA
Post Number: 2333
LOL.. too slow.. :-)
all at the same exact time...
Username: Rovin
Trinidad & T...
Post Number: 7355
read this
http://wickedcases.com/caraudio/charging.html
