Treo ssi
Username: Kyle_lowe
Post Number: 16
i have decided on the treo's over the rl-p but now i dont know which amp i need. can anyone suggest a good 1000watt amp that will not empty my wallett?
Username: Kyle_lowe
Post Number: 17
that would be the treo ssi
Los Angeles, CA USA
Post Number: 3649
how much are you willing to spend?
here are a few amps you can use.
jl 1000/1
kicker kx1200.1
orion 1200d
re 12.1
i know these are 1200wrms amps but the ssi will take all the power you give them.
for less money look in to some hifonics or audiobahn (don't laugh. the amps are pretty decent.).
