Ok...I want to install a second amp to run two 12inch subs. My question is do i need to do anything special besides just hooking up power from the battery, grounding it, and connecting rca cables from one amp to the other? any info would be nice. thanks
you'll need an adequate size main power wire to handle the current of both amps. run you another ground for the new amp, try to ground it at the same point as the other amp. run you the RCA's you need for the new amp. hook up the subs. set the gains and filters and you should be good to go.
They are both going in the same box. I have power going to the two amps....2 seperate wires though. I was just wondering if all i need is a rca jack going from one amp to the other....or if i need another remote wire.... I grounded the amps at the same point....but two sides of the car....do i need them at the same exact point?
