Which Amp?
Username: Jibberishballr
I just got two Alpine Type R's wired at 4 ohms. What would be the best amp under 300 dollars that will sound the cleanest for these subs? Loundness doesnt hurt either
Username: Dustin3
Tigard, Or U.S.
Post Number: 793
i heard that they sound really good with the kx1200.1, i would look at that. also make sure you have the subs in a ported box because they dont sound good if in sealed. look on ebay for it. or maybe look at a RE12.1 on www.reaudio.com, and call them to see what the price would be
Username: Dustin3
Tigard, Or U.S.
Post Number: 794
actually, if you were on a budget, def get this:
http://cgi.ebay.com/HIFONICS-BXi1606D-Class-D-Mono-Amplifier-Amp-BXi-1606D_W0QQi temZ9712213318QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
its puts out 1400 @ 1 ohm
