Kicker and orion
Username: Blk02ss
Post Number: 34
do kicker and orion amps put out what they are rated at? and how are they in terms of Sound Quality. how does the kicker kx and orion D compare to the jl slash series in SQ?
Username: Dontcare
Kicker definately puts out more than what it is rated at. As for orion, i've never had my 2500d bench tested to see, but I can tell you that it puts out some massive,clean power, and I wouldn't be surprised if it really wasn't putting out 2500 watts. Never used JL personally, but I think jl is way overpriced, although a very good product.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 396
the three have good SQ and put what stated or more
Username: Dustin3
Tigard, Or U.S.
Post Number: 744
the kicker amps are a little underrated. i think the 1200.1 puts out 1360
