Bass Question
Username: Vc23
Post Number: 13
Whats up with the bass that you can hear outside the car when someone is driving by your house, verses some subs you just hear the trunk rattling or even the whole car? I want the bass outside the car, so what should i do, but also to sound like that inside? any tips or what?
Username: Matt12490
Benicia, California USA
Post Number: 607
pretty simple.. just get a powerful system, dont deaden your car, then turn it up and roll your windows down. but wanting bass on the outside of your car is stupid. it can cause people to follow you then maybe steal your stuff during the night, or getting tickets by the cops.
Username: Vc23
Post Number: 14
what about in the db drags? all you hear is the whole car shaking, like the windows and trunk and waht not, like when people are hitting 150 dbs? any answer
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 832
just tape your subs to the top of your car. it will be sweet, i swear.
Username: Vc23
Post Number: 15
why would you want to do that? wouldn't they fall off because of all the vibrations?
Username: Matt12490
Post Number: 612
hahahaha! he was kidding. well do you want to get into competitions and the 150 db range?? if you just want to have a nice loud system for everyday listening, i guarentee you dont need it to be in the 150 db range. let us know what you really want.
Username: Vc23
Post Number: 16
i just want a better system than every one else, my friends got a 12w6, so i want it to sound louder than his, i can hear his bass over mine (stock stereo in my explorer)so i was thinkin about gettin 2 12w7s or 13w7s which one is better? but yeah i just want something that alot of people can hear and sounds hella good but really booms. i am obsessed with the hard hitting bass, so what should i do $2500 dollar limit on everything.
Username: Proks
Post Number: 57
thats why you get an alarm system, andyou wait by the window with your rilfe, full loaded HAHAHAHAHAH, shoot holes in those b*tches;)
Username: Groundshaka07
dude, i have 2 15" kicker solobaric L5's, they shake the ground. im serious man they will blow those w7's out of the water. I got them for cheap too, at hookedontronics.com
Username: Vc23
Post Number: 17
do they just get loud or do they actually sound good
Username: Vc23
Post Number: 18
im basically only looking at the subs here, going for like maximum 800 bucks, whats the best subs for people hearing you and sounds hella good?
Username: Proks
Post Number: 60
train horn, they pump
Username: Rovin
Trinidad & T...
Post Number: 7159
$800 for subs u say
& how much $ u willing 2 spend on some good amps !?.......
Username: Vc23
Post Number: 20
about 500 or even more, but no more than 600. what will that get me?
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 722
1 13w7 powered by a jl 1000/1 in your explorer will blow away your friends system. those of us that have cars cannot get the bass to travel or sound quite as deep as SUV's w/ systems everything sounds louder in an suv. so if you have 1 13w7 it will sound like 2 normal 15's and have great sound quality plus be really deep.
Username: Pelona
California
Post Number: 1211
"dude, i have 2 15" kicker solobaric L5's, they shake the ground. im serious man they will blow those w7's out of the water. "
the w7s are alot louder and sound alot better than the l5s
Username: Vc23
Post Number: 21
yeah dudes and there kicker subs man only know the greatest
Username: Rovin
Trinidad & T...
Post Number: 7161
so its really $1200/1300 for 2 12" subs & 1 or 2 amps ????..........
Username: Vc23
Post Number: 22
which is better tho 12w7 or 13w7 cause i have heard many different opinons on them but, what if i ran 1000/1 do lets say each one, what would sound better? also would you be able to notice a big difference if i got w7s and 2 amps or not raelly? cause double the $$ should mean double the boom, but not sure? ??
Username: Vc23
Post Number: 23
maybe 1 sub and 1 amp, but if it is a great difference getting 2 subs and amps then will get two. any advice?
Username: Rovin
Trinidad & T...
Post Number: 7162
4 ur budget u should get a new model 15" xxx & a orion 2500 amp & it will slam & sound good & still come in under 1300.....
Username: Vc23
Post Number: 24
ok so it comes down to it, 12w7 with a 1000/1 or 15" xxx with a orion 2500? which one is the best deal or best sounding? which one would you choose? and why
Username: James1115
Ct
Post Number: 5536
dont forget a new alt which will prob run another $400 or so.
Username: James1115
Ct
Post Number: 5537
your new alt has to be atleast 1.21 jigga watts in order to power what you need.
Username: Vc23
Post Number: 25
alright thanks but what subs would you pick?
Username: Rovin
Trinidad & T...
Post Number: 7165
yep what james said ^^^ - put aside some $ for it
i dont think new 15 xxx has been released as yet but every1 is expecting it 2 be a great sub
it should beat ur other choice in volume - i'd pick 15 xxx/orion combo ...
Username: Vc23
Post Number: 26
i don't even got my liscense yet, in about 4 months i get it, only 15 years old but i got an explorer and i can't even drive it. so i was just takin some advice
Username: James1115
Ct
Post Number: 5538
15 in SI mag:-) with a jl 1000/1 to it:-) that will leave your boy frowning for days. Talk to showrides on here for a SI mag or alteraudio.
Username: Rovin
Trinidad & T...
Post Number: 7167
"1.21 jigga watts" - LOL !......
Username: Theweasel
Post Number: 80
right now the 12" XXX is out and everyone who has it says it is much much much louder than the W7's. and because of its massive excursion the low notes shake the ground. it is about the same price as a 13W7 too. wait til the 15" comes out and power it with a viper 2500 or a orion 2500d.
Username: Viva_la_bam
Post Number: 31
on a car like a chrysler 300c would 2 12 jl audiow7 would that be good sql or would it suck and i wana know what kind of box will work on my car for the woofers and i was told that for a car it is hard for a system 2 sound good its that true if it is tell my why
ok, ive already tested my kicker 15's against that w7 bullshit and i made the kid blow a fuse. dont tell me w7's are better cuz i KNOW they arent.
Username: James1115
Ct
Post Number: 5543
what model kickers? Just because the kid blew a fuse is a problem with his install, not his subs. w7's are very very good subs and will compete with the best of them out there.
im not sayin they arent good subs i just know the kickers are way better
