Wiring subs
Username: Bigbass123
Springfield, CA United States
Post Number: 9
i just wanted to kno how to wire my subs. i got a mono amp and 2 dual 2 ohm subs. how should i wire them to get 2 ohm load. should i wire them together to produce a 2 ohm load or should i wire each speaker separately and then connect them to the amp. any help would be appreciated and if you can show me any wiring diagrams that would be even better.
thanx
Username: Paps
Yuma, AZ
Post Number: 9
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC2x2
Hope this helps you :-)
Username: Paps
Yuma, AZ
Post Number: 10
I believe Option #2 is what you are talking about.
