PVC Port help??
Username: Thomas_g
NM
Post Number: 151
How do you tune a PVC port? Thanx guyz.
Username: Rovin
Trinidad & T...
Post Number: 7037
http://www.the12volt.com/caraudio/boxcalcs.asp
Username: Thomas_g
NM
Post Number: 152
Thanx Rovin!
Username: John_wash
Nashville, Tennessee
Post Number: 190
what size pvc pipe should for my box? i want my box tuned to 30hz but i read somewhere that too small of a pvc pipe will make port noise. so how big in diameter should i go.
Username: Rovin
Trinidad & T...
Post Number: 7040
larger pipes mean longer pipes - play around with that calculator
if u have space & carpentry skills then
http://www.accelerator-pedal.com/ported-box.asp?Ew=21.5&Eh=15.5&Dia=6&Xmax=18.2& Vd=.071&NumW=1&Vb=1.3&Fb=32&Qts=0&Vas=0&Fs=0&CE=1.5
Username: John_wash
Post Number: 192
thanx Rovin thats a very helpful site but do you know where i can find driver displacement for a kicker cvr15
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 218
I have a 1.80cu.ft. box and my ports are at 36Hz, both 3"x14.75", and i don't have a hint of port noise, but it blows out a lighter by my HU, just one 12" TypeR.. and try the kicker site for the displacment, or the spec sheet that came with the woofer.. it'll say, "Displacment Bottom" or it might say "Displacment top (magnet out)"
Username: John_wash
Post Number: 194
ok so i went to that site Rovin suggested but i see that slot ported boxes take up a whole lotta space so im just going to do a pvc ported box. Im going to be using a 6" port so could this work? Upload
Username: Rovin
Trinidad & T...
Post Number: 7048
what i rec u doing each sub with its own separate chamber/volume space - NOT a box that has both subs using 1 air volume, all it costs u is an extra pic of mfd .
They r lazy ppl who will follow my post saying 2 subs in 1 airspace is fine - ITS NOT ! separate has advantages , let them go read y cause i'm not gonna type it out 4 them .
3" pvc ports r good 2 work with as 4" tend s too be quite long - play with the nos on the calc 2 see what fits ur needs best .....
Username: John_wash
Post Number: 196
ok Rovin i will put them in separate chambers but whats a good tuning freq. for them. i want it to hit hard and low but where i can feel it but I DO NOT want bass thats hurts the ears too much.
Username: John_wash
Post Number: 198
bump for help^
Username: Rovin
Trinidad & T...
Post Number: 7049
depends on the subs u have & its specs
generally what ppl mostly go with - lowest around 28hz & highest 35hz , some ppl go even higher in SPL comps
(lower the no better the SQ & vise versa) pick a number between 30/35 to see how ur box dimentions/port could fit comfortably in ur ride .
This ^ is NOT the professional by the book method but space is an issue & sometimes u have 2 fiddle with a design dimention/tuning 2 get it 2 fit ......
Username: John_wash
Post Number: 199
ok thanx Rovin u've been a huge help. oh yea do your type r's hit low
Username: Rovin
Trinidad & T...
Post Number: 7052
yes i would say - hits deep shaking my steering column
quality of amp also determines how clean & bass freq u get
ex - few days ago i sold my MB Quart Raa1000 amp & it plays quite good but 2day i temporarily installed my bro's power acoustic A2100D amp & it plays louder than the MB but i feel that the MB amp played the low freqs ALOT better & its SQ is also ALOT better than this PA amp which is rated ! 2100wrms (PA amps r overated in wrms though) .
Whatever subs/system u doing spend the $ on a decent quality amp .......
