Input on 9835 ?!?
Username: Bakerj72
Regina, Saskatchewan Canada
Post Number: 112
could i put audio-in via rcas into that unit? as in could i hook up an mp3 player through a headphone y jack to my head unit?
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 831
Username: Graphix1
Post Number: 832
next time say what ur talkin about...lol
http://www.crutchfield.com/S-MHpKFQAj0We/cgi-bin/ProdView.asp?g=300&id=detailed_ info&i=500cda9835
im lookin at the specs...it says:
Auxiliary Input Ready: With the addition of the optional KCA-121B Ai-NET/RCA interface cable, the KCA-801B auxiliary input adapter, or the KCA-410C Versatile-Link Terminal, the audio from an auxiliary source can be played through this unit. When the KCA-121B interface cable is used, a CD changer cannot be connected to the head unit; the KCA-801B auxiliary input adapter allows you to connect an auxiliary source and an Ai-NET changer to the head unit. The KCA-410C Versatile-Link Terminal allows you to feed audio from up to two auxiliary sources and two Ai-NET CD changers to the head unit.
So yes u can put audio-in via rcas into that unit..
