Subwoofer for SPL
Username: Cjackson
Chattahoochee, FL USA
Cerwin Vega STROKER154
JL Audio 10W7
Massive Audio DMX15 Stage2
MA Audio HK15X2
Kicker 06S15L74
Which of these would be the best for SPL? Any other kind of subwoofer that you would recommend within the price range of $300-500? It will be powered according to the RMS rating, which depends on which subwoofer is chosen. So I can't choose an amplifier till I choose the subwoofer.
Username: Redliner
Wilmington, Ma
Post Number: 1176
are you looking for a sub for that much or sub and amp for that muchbecause i would get a 15" re sx or something like that i think there 300 shipped from re
Username: Ear_splitter
Post Number: 10
as;ldkfkjeidpaiwurbkneowiaoidj;lbkaljseoijposij;lkbjasljd-=-----=-=-=-=-=--=-bbb bblllllaaaaaahhhhhhhh!!!!!!!!-=--=-=-=--=-=-timmy!!!!!-===-=-=-timmay-==-=-=-=-t imon=--=-=-=-jjjjjlllllll--===-=-all the fu**** way
Username: Kravenblood
Ohio
Post Number: 44
i got a stroker 154 its loud i have it in a sealed box, i know its louder than the kicker but not sure about the others.. dont know how,loud it gets in a ported either not putting it in one till i get my stroker pro 15 then my stroker will be made into a home theater sub
Username: Cjackson
Just subwoofer.
Where do I buy RE products from?
I'm basically planning on spending about $500 on a subwoofer and $500-750 on an amplifier to power it. I'm looking for SPL, SQL isn't as important for this particular system.
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2133
www.reaudio.com
^^^^RE prods
ok dude hopefully u have a HO alt, and if u do...get a RE MT with dual 2 ohm coils and get 2 Viper 2500.1's
run one to each coil
Username: Kicker_kyle
Post Number: 12
I would get a 15" Mmats juggernaught and abig slot ported box
