Best HU For I-Pod Hook Up
Username: Vc23
Post Number: 28
Whats the best and eaistest to use HU with an i-pod,(30g video)and under 400 bucks?
Username: Dkchillin
Vermont
Post Number: 39
Most decks can be fairly easily rigged to hook up an iPod but if you're looking for a fairly cheap, one cable opperation that lets you actually control the iPod from the Deck, almost all of the new midrange Alpines use their KCE-422i Ipod Control Interface cable and that just plugs into the back of the deck and then into your iPod. Like I said though, with very little effort you can do almost the same thing with most decks (minus actually having controls on the deck itself), so I wouldn't let iPod connectivity be your deciding factor.
Here's a link to all the different AUX-in cables for different brand HUs that you could use to run your iPod. I use the PIE PIO/P-RCA Adapter on my Pioneer HU.
http://www.crutchfield.com/S-1F9MQThxP7J/cgi-bin/ProdGroup.asp?g=227550&avf=N
