Any Suggestions?
Username: Benwestt
Ocean Springs, Mississippi United States
Post Number: 23
I am going to get:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9704893583%26&sspagename= STRK%3AMEWA%3APIC%26
any suggestions on a amplifier? looking for one for $200 and under...
Username: Killer44
Ontario Canada
Post Number: 477
audiobahn A8002T (RUN THEM 2 OHMS PER CHANNEL)
Hifonics bx1005d (run them both down to 1ohm, it says it puts out 1000rms but it will do more like 700-850 rms perfect for your subs)...
Username: Benwestt
Post Number: 25
good price?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9705899453%26&sspagename= STRK%3AMEWA%3AIT%26#top
Username: Killer44
Ontario Canada
Post Number: 478
yep, jsut make sure u get the dual 4 ohm version for your subs like the ones in your 1st post, and then wire them like diagram 1 in the following link (wire each sub seperatly)
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =1&impedance=DVC4x2
alot of ppl dont like audiobahn anything, im not a big fan (but they make a a good budget amp, A8000T and A8002T, theyre Alumq subs are also alrite IMO) u should be good with that amp post some pics once u get it all hooked up...those are great subs for the money i got the 10" ones for my s10...well if ya go ne more questions im going out rite now but i should be back on later on...
