My equalizer
Username: Bga44
Tampa, FL
Post Number: 198
i have a 7band power acoustik equalizer. When i connected it to my bros system it wasnt as loud as it was without the EQ. What is the problem with that?
Username: Mrdark
Post Number: 174
maybe the EQ isnt set right or the line out signal somehow was dilluted/reduced in voltage a bit? anyone else?
Username: Nypdlapd
wirin could be wrong>>>>>> Is it amplified
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11272
pre-out voltage may be lower, or the EQ may have an attenuator that needs to be turned up (master level or volume control)
Username: Kevin420
Gilbert, Az USA
Post Number: 13
any gain adjusts on the eq?
