Brahmas vs L7s?
Username: Alexv3305
Tavernier, FL United States
Post Number: 7
Do Brahma Mark II 15s hit harder than Kicker 15" Solo-baric L7s?
Username: James1115
Ct
Post Number: 5417
as far as SPL the l7's get loud, but the brahma's will keep up but when it comes to SQ the brahma wins all day long.
Username: Alexv3305
Post Number: 8
the brahmas have way more linear excursion so i think they should get louder right??
Username: James1115
Ct
Post Number: 5418
only if used in a sealed enclosure is xmax a factor. There are many other factors that contribut to how loud a sub will play such as BL(BL is determined by the flux density (B) in the magnetic gap and the length (L) of voice coil wire in the gap. A higher BL will generally mean a speaker will have a higher relative sensitivity (efficiency). This doesn't necessarily mean that all speakers with a higher BL will produce a higher SPL. Often speakers with very high BLs have a smaller Xmax) this plays a larger role in ported enclosure where small xmax is ok, SD which is surface area of a sub which determines the amount of air moved, depending on the box you choose makes all the difference and also how they are powered.
Username: Alexv3305
Post Number: 9
so which will get louder? a kicker l7 15 in a ported box or a 15" brahma mark 2 in a ported box??
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2581
The L7 would prolly be louder, but the Brahma wouldnt be far behind.
The difference in SQ would be night and day though. Once you hear a properly installed brahma, you will be comparing L7's to a monkey banging on a trash can.
Username: James1115
Ct
Post Number: 5419
lol
