New pics of re audio subs and specs check them out
Username: Extrmndor3
Chicago, Ill Us
Post Number: 233
i think the mx will be like the mt cuz 4 inch voice coil and the xxx only 3, and the mx has neo magnets im not sure of the xxx wat you think
plus i will post pics of the specs of the new 4 channel amp
Username: Extremesound1
Coventry, RI United states
Post Number: 87
whats the rms for the xxx and the mx i cant read that!!!!!!!!!
Username: Jmloughrey
Farmington, CT
Post Number: 1464
it doesnt tell you the RMS..
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2558
MX---1500wrms (kind of an old XXX replacement...22mm xmax)
new XXX---2000wrms (end-all, be-all SQL sub...54mm xmax)
Post Number: 2560
http://forum.carstereos.org/showthread.php?t=58992
info on the 2006 RE lines...posted by David from RE.
Chicago, Ill Us
Post Number: 239
damn 54 for xmax man thats going to be one cool sub and how will be compare with other subs like the dd their top of the line or other subs
Username: Sw9152
Michigan
Post Number: 265
do have a link to where you got those pics?
Chicago, Ill Us
Post Number: 241
Chicago, Ill Us
Post Number: 242
Username: Safe_cracker
Chicago, IL US
Post Number: 574
An Fs of 21, gonna tune low on its own, better raise the port tune a little. This box design I have with a 42hz tune may come in handy just need to beef it up a lot, lol. Polo.. :-)
Chicago, Ill Us
Post Number: 243
Username: Young_james
Post Number: 1088
gotta love the way the mx and xxx look
Chicago, Ill Us
Post Number: 245
the magnets should be alot bigger it doesnt look to good with those magnets but they are neo magnets (i dont know wat that means but wow)
Chicago, IL US
Post Number: 579
They are Brochure pictures....
Username: Rexxx1
Hartford, CT US
Post Number: 11
new 15in XXX, 76 pounds, 2000 watts rms, 54 mm , dual 2 ohm
DDDDDDAAAAAAMMMMMMNNNNNN!!!!!!!!!
i think i just sh!t my pants
and i want two of those i think im sticking with one im ordering in 3 months when i have the money i heard it was 670 for shipping to
Chicago, Ill Us
Post Number: 247
yes how did you know u got it too?
Username: Ryanshaw3ball
Post Number: 20
if you all want to know how freggin amazing the new XXX is than i'm your guy. i just recieved my new 18 INCH XXX. holy sh1t! i have it in a 8 cu foot box tuned to 32 hz with 2500 watts rms going to it. this thing had such great sound quality and it thumps harder than any other sub out there. only downside is it weighs a ton and fills up my trunk!
Username: Pelona
Alabama
Post Number: 1062
^^^fuken liar
Post Number: 21
whatever dude, i dont need your approval to listen to some fu cken banging tunes
Username: Ton
Post Number: 26
the MX is Sq or Spl?
Chicago, IL US
Post Number: 585
The new 18" XXX won't be ready until summer, if your lucky. The 15" won't be ready til another month, mine is ordered(pre)with dual four ohm coils because I will be using my two Kicker sx1250s, when strapped they are 2 ohm compatable, 1 ohm unstrapped. Polo..
Chicago, Ill Us
Post Number: 251
the sx need to break in or not
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6305
Hey, ryan's not even telling the truth.lol, tryin to be cool and got caught, that is funny as hell
Chicago, Ill Us
Post Number: 258
whos lying cmon man anyone cant tell me if the sx needs to break in i need to ride with the females and i have my 18 inch ready tomorros ill show you some vids and pics installed please
Post Number: 6306
Is ur sub still under warranty???
If so crank it up until ur ears bleed, if it breaks get another 1..
If no warranty, still crank it up, breaking in subs is a myth. u really dont have to do it, it will start to loosin up over time any way
Chicago, Ill Us
Post Number: 265
yeah right dude some subs neeeeeeds to break in other dont i just bought the sx las thusday so i got the box and everything and i want loud musik right now
Post Number: 6307
nope, no sub needs to be breaked in, that is a myth it really is....Any body who no's will tell u, u really dont have to break a sub in, And if it is a well built sub u shouldnt even worry about blowing it
Los Angeles, CA USA
Post Number: 3334
what are you scared of? you think you are going to blow your sub cause you didnt't break them in? i don't think re makes there subs that cheap. just crank that sh!t up the way you like it and don't worry about breaking it in.
Chicago, Ill Us
Post Number: 268
u got a point there but the subs that i installed the factory said that the sub needs to break in if not the sub will not play correctly ex. plok momo speaker some mtx and the power acoustik mofo
Post Number: 6308
ex: All the subs u named are crappy
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 621
RE told me to break my SX12 in. the spider is really stiff.
Username: Night_mirage
AmmanJordan
Post Number: 214
WOOOOOOOOOW nice new products .
MX looks nice ..
thanks
Username: Solacedagony
New Jersey US
Post Number: 851
There are a couple reasons for "break-in".
Mostly, it's to make sure that your system is setup correctly and you don't go cranking it and destroying speakers.
Second, the suspensions of speakers, like johnny said, may loosen up.
Third, many parts are glued on, and there may be excess glue. I'm not sure if the glue reforms, burns off, what, but that's another reason.
All in all, "break-in" is only as required as you are cautious.
Username: B101
Queen City, NC USA
Post Number: 2087
"new XXX---2000wrms (end-all, be-all SQL sub...54mm xmax)"
umm did u forget TREO SSX!?@!?
SIZE:
18in
460mm
VC:
4.0in
102mm
RMS:
2500
Excursion:
2.68in
68mm
also I hope the nex XXX can take excess of 4000rms...
look sweet though, hopefully they last in competition burps!
Which 1 will sound better??? Still got my $$ on the Treos...
Username: B101
Queen City, NC USA
Post Number: 2088
Username: Mikechec9
Post Number: 2304
"if you all want to know how freggin amazing the new XXX is than i'm your guy. i just recieved my new 18 INCH XXX. holy sh1t! i have it in a 8 cu foot box tuned to 32 hz with 2500 watts rms going to it. this thing had such great sound quality and it thumps harder than any other sub out there. only downside is it weighs a ton and fills up my trunk!"
lol. so, can we get some pics? also, what amp do you have pushing 2500 rms to the sub?
I believe this is just too sad (really, too sad).
*response* "i don't need to prove anything to you guys. I know what i have and i like it. that's all that matters. i was just trying to be nice and let you know. but, oh well."
Username: Pelona
Alabama
Post Number: 1064
^^^lol. ryan shaw........
Chicago, Ill Us
Post Number: 279
yeah the only xxx version that can be ship to custumer is the 12 inch version the 15 is not ready and the 18 more time.
shut up i'll kick you in the nooooootttttttsssss
hippie
Username: Pelona
Alabama
Post Number: 1069
how u know hes a hippie?
Chicago, Ill Us
Post Number: 282
he talks like a hippi and i dont know i just feel, u know is like a gift from good u know its my sixth sense. cuz i hate hippies
Username: Pelona
Alabama
Post Number: 1070
u hate hippies lilrob? why dont u just rap a song about hippies then cabron?
Chicago, Ill Us
Post Number: 284
oh snap senor perdoneme no sabia k aiga hispanos im just playing dude not te emputes se te suben los frijoles just relax bro
Username: Pelona
Alabama
Post Number: 1071
i aint mad foo. lil rob is tight. one of the best mexican rappers
Chicago, Ill Us
Post Number: 288
no dude i dont like lilrob too much cuz his attitude with his muski doesnt fit i just like summer nights thats it try el dyablo chingo bling or stunta clika one and some chente too thats tigh
Username: Pelona
California
Post Number: 1073
u probly like summer nights cuz thats like his only song that went international. chicano rap doesnt realy go international like niggar rap. he has some bad azz ones like Bluffin or No future in it
Username: Rmzracer
Bentonville, Arkansas USA
Post Number: 106
Freddy you are my hero "chicano rap doesnt realy go international like niggar rap." realest thing ive heard in here in while.
Chicago, Ill Us
Post Number: 294
dude i got the cd the black one that has lilrobb and its not cool but i dont have the case
Chicago, IL US
Post Number: 588
lilrob you Mexicano? I thought you were black, lol. Polo. :-O
Chicago, Ill Us
Post Number: 297
hell na im 100% mexican u a white dude right
Username: Pelona
California
Post Number: 1074
foo, everybodys white on this forum. where u from lilrob?
Chicago, IL US
Post Number: 595
Hahha, white or BROWN, lol. Hey with a last name of Carrillo, what you think? Polo.. :-O
Username: Pelona
California
Post Number: 1077
whos last name is carrillo?
Chicago, Ill Us
Post Number: 298
haha polo carrillo mine is roberto rosales white or brown both and u maybe brown(nose)just playing dude im from mexico dude we mexican know how to get loud u know why usac and drag db get to mexico too dude did u saw the black dude from the olympics he was skiing but if u have tivo and slow motit he was cheatin he was craping his pants and fating and with the air he was makin it made him win just like a rocket when lounching if you dont beleive me look at some vids and u will look at that black dude
Username: Pelona
California
Post Number: 1080
yea im from mexico too. san antonio, michoacan. but i was raised in so cal. aint that fcked up wut theyr doing right now about that immigration law?
Chicago, Ill Us
Post Number: 300
yeah im in chicago , this city started with the strike all the people went to the sears tower to strike and i was on the main streetof la villita the hood for mexicans and dude some dudes broke some jewlry window and stoled like 10 thousand of gold i was pasing by and i tooked like 3000 bucks of gold the hard thing it was with some rare names that i even know that exists cuz of that i bough my sx new tv and new computer
Chicago, IL US
Post Number: 597
So what your proud that you stole that stuff? The reason I thought you were black because a lot of my peeps are and they type ghetto like you, lol. I am not racist and cannot afford to be so I deal with everyone on the same level, even you. I still have family in the old hood 24th and St.Louis, been there for a very long time (before your mama born). Most of my family were from Spain, Mexico and Italy, yes Italy lots of spanish there too. When I learned this I was shocked. My Grandfather from Mexico (Mexico City) he has blonde hair and blue eyes as so did I when I was born, now it is brown with blue eyes. Polo. :-)
Chicago, Ill Us
Post Number: 304
good polo so u a brother we are going to keep it cool alright talk to you later
Username: Pelona
California
Post Number: 1083
hold the fck up Polo. so is u mexican or black?
Chicago, IL US
Post Number: 601
Does it matter? I already said where my family is from above not to mention my last name. I wouldn't call myself mexican, but Spanish. I am not brown but white.Polo.
Username: Pelona
California
Post Number: 1086
"When I learned this I was shocked. My Grandfather from Mexico (Mexico City) he has blonde hair and blue eyes as so did I when I was born, now it is brown with blue eyes"
why were u shocked? u didnt know there are a lot of mexicans that look a little bit white. but the really white ones like your grandpa are usually in mexico city cuz they mostly in charge of the government. ive never seen a blonde blue eyed mexican though
Chicago, IL US
Post Number: 604
No I was shocked that there were spanish in Italy. That's just it, his family line is from Spain, big diference. Being mexican is just that, you lived in mexico. Most Mexicans are a mix of spanish and native american/south american Indian, that is where the color comes from. There are a lot of Spanish people out there and they don't have to all be Mexican, lol. I know a lot of white Mexicans and a couple of red headed ones too, kinda funny, try to picture that!
Username: Pelona
California
Post Number: 1089
ive never seen redheaded mexican guys but on girls its common. theres this one guy at our school that is orange haired, brown eyebrows, and freckles on his face and arms. i went to ask him why he hangs out with the mexicans then he says he is mexican. i didnt believe him then he started talking spanish. he said he got the hair from his grandpa cuz he had orang hair too
Username: Pelona
California
Post Number: 1090
"Freddy you are my hero "chicano rap doesnt realy go international like niggar rap." realest thing ive heard in here in while."
yay!! im a hero!!
