Filters and preouts..
Username: Paogr
AthensGreece
Post Number: 8
The filters on a headunit (HPF,LPF) affect the internal amp and the preouts or one of those? I'm asking because my friend's headunit has 1 preout and he has hooked a 1-channel amp on it and a sub. The rest four speakers run from the headunit's internal amp. If he set the HPF at 100Hz will this affect the preout or not?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1643
both.
depends on what kind of pre out that it. sub, front or rear. and which crossover was adjusted. depends on the HU as to how that works.
HPF should only affect the mids and highs though. the LPF should affect the sub.
