What is this part of the sub box called?
Username: Courtreezy
I'm trying to find the part i need for this sub box...i have a picture to explain better what i am talking about...it is the hole where you connect your speaker wires too, but i am not sure what you call that, and where to get them...any help would be great...
http://img453.imageshack.us/img453/3593/subboxhole4ld.jpg
Username: Killer44
Ontario Canada
Post Number: 471
speaker terminal...
http://www.crutchfield.com/S-d2woLcQ0oOi/cgi-bin/ProdView.asp?search=speaker+ter minal&i=073900G
http://www.crutchfield.com/S-d2woLcQ0oOi/cgi-bin/ProdView.asp?search=speaker+ter minal&i=1257001
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=speaker%20terminal
hope that helps...
