Pick between these two woofers. jl or infinity
Username: Langless28
Post Number: 385
jl 12w3v2 or a infinity kappa perfect 12.1d ported getting 300 watts at 2ohm. which one should i get for sql. i have a 97 jeep cherokee
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6336
jl by a mile
Post Number: 386
thats good to know, can u explain why? my friend had a that jl in a trunk and didnt sound to good. (but it was a trunk and the idiot only hooked up one vc) and i have never heard a infinity in car, only at tweeter.
Post Number: 387
replace trunk with truck in my previous post. lol so spaced out today.
Post Number: 389
some more opinions would be great.
thanks-
Username: Pelona
Alabama
Post Number: 1065
get the jl. jl is one of the best brands of subwoofers with one of the best sq. and yeah it will get louder than the 12.1d and sound better. but those infinitys dont sound too bad either
Post Number: 390
freddy have you heard them both personally. i know i have heard that the 12w3 are great but it just looks so whimpy (ha)
Username: Rwells
Atlanta, Georgia United States
Post Number: 31
dont under-estimate JL. they are like the ferrari of car audio. very high quality stuff that you can depend on. i have a friend who is a manager at Hi-fi buys. he said that the biggest thing with JL, is that you can bet it will work for a long long time; with that and the quality, infinity doesnt stand a chance. infinity has great car audio no doubt, but home audio is more their specialty.
Post Number: 391
thanks, and this might be a misconception, but are rubber surrounds better than foam. thats what i heard. maybe you can straighen that out for me
Post Number: 392
also looking at other compaines like treo, i think i am mistaken about foam surrounds
Username: Delsole
Post Number: 242
jl is clearly better in many ways but price wise i believe infinity is cheaper
keep that in mind
Post Number: 393
and on that jl audio. should i build a box 1.6 cubes tuned to 21hz or jl's reccomened 1.75 box tuned to 30hz
Post Number: 394
i meant 31hz
Username: 60buck
Webster, Ny
Post Number: 82
u may want to also look into that of the kicker cvx. if your planning on jl, anything would be good. i am not impressed with the 1's though. keep in mind that the w3v3's will be coming out shortly.
Username: Pelona
California
Post Number: 1075
i heard 10w3s and 12"12.1ds and trust me the jls are better. theyr just too expensive
Post Number: 397
when will the w3v3 be commin out? anyone know specs?
Username: Pelona
California
Post Number: 1079
actually the w3s arent too expensive but more expensive than the infinity
Post Number: 398
yeah i think new they are 200 online. i think my local audio shop, they sell new for like 180. when are the w3v3 comming out. cus i wont be buyin the sub till may cus im still in school and dont have my car.
Username: Pelona
California
Post Number: 1082
i think u should get a car first then buy a system. lol
Post Number: 399
no i have a car. i go to school in boston so i dont need one up here. it already has a system in it, just upgrading the sub this summer
Username: Rwells
Post Number: 34
cvr's are worth your while too. cheap, and put out tons of bass. i just installed 2 in my car and im very impressed!
Post Number: 400
ok jl is better than infinity, now which one is better for SQL, ported, getting 300w at 2 ohm: 12w3v2 or image dynamics IDQ12D4 v.2
