Bronze Member Username: Ryanshaw3ballPost Number: 15 Registered: Mar-06 | what are some good sub and amp packages for under 800? |
Gold Member Username: RovinTrinidad & T... Post Number: 6882 Registered: Jul-05 | what size & how many subs can ur ride hold ?...... |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 3323 Registered: Oct-05 | you want one or two subs. also do you want clean sound or just loud? |
Bronze Member Username: Ryanshaw3ballPost Number: 16 Registered: Mar-06 | 2 15 " or 1 18" 6cubic foot box in my trunk |
Bronze Member Username: Ryanshaw3ballPost Number: 17 Registered: Mar-06 | i'd like some loud azz subs but with some pretty good sq |
Silver Member Username: Sw9152Michigan Post Number: 258 Registered: Feb-06 | eclipse titanium 15" in a 4.5 cu ft ported box tuned to 32 Hz with a rockford fosgate X7 amp. |
Silver Member Username: Sw9152Michigan Post Number: 259 Registered: Feb-06 | never heard one but i think resonant engineering has a 18" xxx. |
Silver Member Username: Sw9152Michigan Post Number: 260 Registered: Feb-06 | you will also want a HO alternator for anything over ~1200 watts. |
Gold Member Username: RovinTrinidad & T... Post Number: 6883 Registered: Jul-05 | 2 RE SE 15" = $400 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14805 |
Bronze Member Username: Ryanshaw3ballPost Number: 19 Registered: Mar-06 | i hear really good things about re and i was wondering if anyone has heard a 15 or 18 inch sx? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 3324 Registered: Oct-05 | sub: 2 of these 15" kicker cvx http://cgi.ebay.com/BRAND-NEW-2006-KICKER-CVX15-15-SUB-DUAL-2-CVX-15_W0QQitemZ97 03392059QQcategoryZ58035QQssPageNameZWDVWQQrdZ1QQcmdZViewItem amp: kicker kx2500.1 http://cgi.ebay.com/Kicker-KX2500-1-Mono-Amplifier-Amp-2500-watts_W0QQitemZ97020 60013QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem it might be a little over your budget but it will sound loud and pretty decent too. |
Bronze Member Username: Jeffless600Post Number: 62 Registered: Feb-06 | Get a 12" Kicker SOLO X. and a Hifonics Amp. That will be perfect..lots of spl....ok sq |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 3327 Registered: Oct-05 | that won't get louder than the 2 15 cvx powered by kx2500.1 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6298 Registered: Jul-05 | ^^agreed I would get 2 of these http://www.realmofexcursion.com/store/product_info.php?cPath=21_62&products_id=1 15 with http://ikesound.com/product-product_id/3284 |
