Poli-Fill huh??????
Username: Panache
Brenham, TX US
Post Number: 25
Ok, I know what poli fill is for. the question is what does it do to make it your box sound bigger?
sound bigger? if your box was made to big you can use poli fill to take up sum of the air space and somtimes to clear up some ratles
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2592
polyfill will serve to slow the transmission of the soundwaves to an extent, making the box appear about 10% larger than actual size.
polyfill also helps if the box is "square" with the rear surface and the front in parallel, by reducing standing wave reflection (SWR) which cancels bass.
this is why many boxes have one side angled.
