New system, well, yea
Username: Joesmith1
Snellville, Ga USA
hey guys, i got a free set of MA Audio 12 inch subs and i was wondering if they were good or not. and also had a question about hooking them up to my amp.
Username: B101
Queen City, NC USA
Post Number: 2044
sell em, if their still in box..
Username: Nypdlapd
Post Number: 143
Wat amp??
Username: Goatin
U.S.A
Post Number: 608
Not really but FOR FREE is always great!!
What is your Question?
Do you know the model of the subs and amp?
Username: Joesmith1
Snellville, Ga USA
yea the ammp is a 600w sony xplod amp. 2/1 channel power amplifier XM 2100GTX. the subs are MA 121XG dual 4 ohm 600 watt. would i need a capacitor for my alternator also?
Username: Redliner
Wilmington, Ma
Post Number: 1132
no you do not need a capacitor theres no need the sony amp wont put out close to that in the first place and a good rule of thumb is 1000 watts and then a ho alt not a cap because a cap wont do anything for you with out something to charge it it will just add strain to your alternator and most likely kill it and then yu will hvae to buy a new one hope this answers your question
Username: Joesmith1
Snellville, Ga USA
yea it helps alot. thanks
