Best 18's
Username: Bass321
I have a Tsunami 1800 db 1800t amp and i need to know what two 18s would go best with this amp.
someone
Man, you really want 18's? They sound so sloppy though.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2975
resonant engineering maybe.
Username: Bass321
Well if not 18s then what would be the best subs to go with the Tsunami amp? I dont believe my se's would work since the amp is 1800 watts at 2 ohm. I want to be able to run all 1800 from the amp.Thanks again for the replys Glass.
