Does shape of box make a difference
Username: Blackf150
Raceland, La Usa
Post Number: 13
building a new sealed box and wondered if a square box sounded any different from a triangle
Username: Rovin
Trinidad & T...
Post Number: 6856
there have been a few articles on this online
basically - do not build a perfectly square box , rectangular is preferred
tests also show a slight benefit of using a trapezium shaped box (2 sides parallel , either fr/back 90 degree & remaining side slanted slightly) over 90 degree walls - but its alot more difficult to build though if u have the skills & time to go right ahead .
Easiest box to built is rectangular ......
http://www.the12volt.com/caraudio/boxcalcs.asp
& http://www.accelerator-pedal.com/ported-box.asp?Ew=30&Eh=12&Dia=4&Xmax=8.6&Vd=.5 &NumW=2&Vb=&Fb=42&Qts=0.400&Vas=2.45&Fs=24.2&CE=1.5
Username: Blackf150
Raceland, La Usa
Post Number: 14
yea i had ported like that and just wanted to make a quik sealed to hear the sq difference
Username: Lewass
Boomfield Hills, MI USA
Post Number: 403
Sealed is definitely better sounding, no doubts about that.. The bass "fill" is more pronounced with sealed, while the impacts will be better in the ported.
Username: Blackf150
Raceland, La Usa
Post Number: 15
also does polyfill insde make a huge difference
