BEST CAR AUDIO BATTERY!
Username: Jeffless600
Post Number: 59
I have to change my battery soon and im wondering what battery you guys think will help/do the best for my car audio system. Right now im thinking Optima Yellowtop..thats all. Any better ones out there??
Username: Nypdlapd
Post Number: 151
STINGER
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1504
Odyssey makes Stinger's batteries. Stinger just puts their name and price increase on them.
Look at kinetic too. or just go with the yellow top.
all good, not sure if ones better then the next though.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11399
yeah I'd say Odyssey/Stinger or Kinetik.
Username: B101
Queen City, NC USA
Post Number: 2082
yea Im with the GW on this!!
Kinetik then Odyssey/Stinger...
Username: Lewass
Boomfield Hills, MI USA
Post Number: 460
How does Optima Yellow top compare price/output wise??? Should I return my yellow and get a full size kinetik? In the end I won't be running more than 2000 watts...
Stockbridge, GA USA
Post Number: 1590
i'm not sure if either is better then the other, but if you already got the yellow top, keep it.
Username: Suleman36
Maryland U.S.A.
Post Number: 3406
If im running my system with a 200A HO alternator and 2 amps that put out a combined 1200 watts rms and a 1 farad cap to both amps.
Im planning to replace the old stock battery with a new one. What battery whould be the best choice for a starter in this case ?
Username: Suleman36
Maryland U.S.A.
Post Number: 3408
I imagine a Optima Redtop or Yellowtop whould fit the bill. I use a yellowtop in my SUV as a starter and its been great so far. Seems like the Redtop is better off as a starter battery giving it more power in the first 10 sec etc...
Not sure which one to get.
Username: Nypdlapd
Post Number: 177
Get stinger/odyssey its smaller and more amps than yellowtop
Username: Suleman36
Maryland U.S.A.
Post Number: 3409
Where is the cheapest place online i can get stinger or odyssey.
Also its replacing my stock battery and i have a 1 farad cap in the trunk already along with a 200 HO alternator.
Username: Suleman36
Maryland U.S.A.
Post Number: 3410
So i went to sears and advance auto parts around my way and they didnt have a optima battery that fit my 1998 Toyota Camry.
What is the next option that will replace the stock battery for this car for my application.
Username: Nypdlapd
Post Number: 178
Stockbridge, GA USA
Post Number: 1599
Odyssey or Kenetic. they make several different versions of the Yellow top for different cars. why wouldn't it fit MO?? look at the CCA ratings if your concerned about starting. don't run a system off a Red Top alone. it'll be just like keeping the stock battery.
Username: B101
Queen City, NC USA
Post Number: 2143
1 2150 stinger/odesey is the equivalent to 3 yellows ive heard. :-)
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2607
also, look at NorthStar.
NSB90
NSB125
NSB170 <<<big SOB!
Username: B101
Queen City, NC USA
Post Number: 2154
yeap, but ill have to make room for the nsb170 :-)
The NSB are telecomunication batteries.
Username: Nypdlapd
Post Number: 179
AND ive heard that TO B "1 2150 stinger/odesey is the equivalent to 3 yellows"
Username: Suleman36
Maryland U.S.A.
Post Number: 3411
Here is what stinger emailed me with:
The SP1000 would be a great battery to replace the factory with. It is one of our most versatile and most sold batteries.
Brian Miller
Brian Miller
AAMP of America Technical
http://cgi.ebay.com/ebaymotors/STINGER-SP1000-POWER2-DRY-CELL-CAR-AUDIO-BATTERY- NEW_W0QQcmdZViewItemQQcategoryZ33574QQitemZ8050452286QQrdZ1QQsspagenameZWDVW
