Help make final decision
Username: Langless28
Post Number: 363
i was looking into the infinity 12.1d for my xtant a3001 amp (300w at 2ohm) any sub that are better in sql for 200 or under. i prefer ported boxes too.
Post Number: 367
anything
Username: Extrmndor3
Chicago, Ill Us
Post Number: 145
ascendaty audio assasins man it will be hell of sq one of the best you can buy right now
Chicago, Ill Us
Post Number: 147
is like 100 shipped
Post Number: 368
yeah but isnt 4ohm svc. my amp does 150 at 4 and 300 at 2 ohm sooo.
Username: Palanza
Post Number: 90
I have 2 of those infin. subs, they work great :-)
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1470
RE re, its dvc4ohm, and like 200wrms. and its only like $75 shipped i think.
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 359
infinity is a good system... but..... they are better for a sealed enclosure...... So..... :-)
Username: Seth_walker
U.S.A.
Post Number: 18
12.1d's are pretty good. I have two in a sealed box. They have excellent sq but I find their ouput isn't very good with the really low notes. However, if you're more into sq then they should suit you great.
U.S.A.
Post Number: 19
12.1d's are pretty good. I have two in a sealed box. They have excellent sq but I find their ouput isn't very good with the really low notes. However, if you're more into sq then they should suit you well.
U.S.A.
Post Number: 20
Oops! didn't mean to double post.
