Wiring subs
Username: Rswan
Post Number: 11
if i want to get 2 ohms out of 3 6ohm subs should i wire them in series/parallel or parallel/parallel
Username: Rswan
Post Number: 12
oh yea they are dvc
Username: Bdb_86
Bemidji, MN Usa
Post Number: 126
as glasswolf seid to you before wire them all in parallel together then you well have 2 ohms
Username: Its_bacon12
Post Number: 484
no, if you wire them all paralell you will get a 1 ohm load
there is a section on www.bcae1.com to figure this out
im not quite sure there is a good way to wire them like that...........
Username: Rogers22money
Owego, Ny Tioga
try to run them the seires paralell way and see if that gets you the 2 ohms that you want.
Username: Bdb_86
Bemidji, MN Usa
Post Number: 127
https://www.ecoustics.com/electronics/forum/car-audio/20996.html
6/3=2
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2562
try this calculator
http://www.the12volt.com/caraudio/boxcalcs.asp#par
6=6=6 in parallel is 6/3 for resistance or impedance. trust me, it's 2 ohms.
Username: Glasswolf
Post Number: 2563
the only way you'd get 1 ohm, now that I think about it, is if your amp is 2 channels, and bridged.
then you'd see 1 ohm.
