Q for Rovin
Username: Matt12490
Benicia, California USA
Post Number: 453
hey rovin i noticed you have the 60.7 CS components im pretty sure. and those are 90watts @ 2ohms and you have a Alpine F545 amp which @ 2 ohms puts out 150watts. do i have this right?? are you overpowering those speaks by 60 watts? i'm just wondering what those speakers can take because i might get some for my brother. let me know thanks.
Username: Rovin
Trinidad & T...
Post Number: 6862
i own this model
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15348
its rated @ 4ohms if i'm not mistaken
& my alpine amp is rated @
RMS Power (at 12V,20Hz-200Hz)
* Bridged 4 ohms : 300W x 1 (Ch-3/4)
* Per channel into 2 ohms : 150W x 2 (Ch-3/4)
* Per channel into 4 ohms : 100W x 4
RMS Power (at 14.4V,20Hz-200Hz)
* Bridged 4 ohms : 125W x 1 (Ch-3/4), 500W x 1 (Ch-3/4)
* Per channel into 2 ohms : 250W x 2 (Ch-3/4)
so it powers them sufficiently
Honestly these comps play all the highs/mids good but bass could be better , then again thats what subs r 4 . Good budget buy but ppl say those (& i must state that i never used any) Mb quart , JL, Boston Acoustics & Diamond comps r all pretty good too .....
Username: Matt12490
Post Number: 454
ooh my bad. alright thanks
