I NeEd EvErYoNeS aDvIcE pLeAsE!!!!!!!!!
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 52
OKAY I HAVE DECIDED TO GET 2 15" KICKER COMPVR'S BUT NOW I NEED A AMP TO SUIT THEM. I WILL GIVE YOU A LIST OF THE AMPS AVAILABLE AND YOU ALL PICK WHICH ONE WILL BE BEST FOR THE SUBS! THANXXXXX ALOT
AUDIOBAHN A8000T
PLANET AUDIO P-850D
HIFONICS BX125D
KENWOOD KAC-9152D
BOSS RT-2500D
MEMPHIS 16-PRD1000.1
POWER ACOUSTIK A1800DB
MA AUDIO HK100D
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 724
the memphis is the only one i would buy.
H-TOWN, TEXAS US
Post Number: 53
but its the most expensive on the list, but hey i ask your advice
Username: Dustin3
Tigard, Or U.S.
Post Number: 615
if your on a budg. get the hifonics because most likely it will put out 1000 watts and for 2 15" comp vr's you should have a 1000 watts amp for them. the audiobahn is onlu 800 watts
Username: Rovin
Trinidad & T...
Post Number: 6785
if i also had 2 buy it would def be Memphis from ur list
but if were me i'd go ebay & get a kicker 1200 or orion 1200d amp.......
Username: Teddy21
Ann Arbor, MI USA
Post Number: 50
the old jbl bp1200.1 would be a great amp and you can get one on ebay for under $200
H-TOWN, TEXAS US
Post Number: 54
correction of the hifonic amp
Hifonics BX1205D
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 788
From you list on a budget I would get the Hifonics, but if it were me I'd get on ebay and get a Kicker 1200.1. Be careful you don't blow the woofers with the kicker amp though
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6207
Maybe would could see a budget
Username: Texas_bass
Houston, TX
Post Number: 301
the hifonics bx2005d puts out 1300 rms @ 2 ohms and 2000 rms @ 1 ohm
