This amp any GOOD
Username: Extremesound1
Coventry, RI United states
Post Number: 46
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3461
its hifonics is it any good LOT OF WATTAGE FOR A 2 CHANNEL AMP
Post Number: 48
ANY BODY IS THIS A GOOD AMP
Username: Sw9152
Michigan
Post Number: 239
yes it is but there are better amps out there for the money. how many watts are you looking for at what ohms?
Post Number: 49
2 ohms, between 1000 to probaly 2000 between and 2 channel
so say 1000x2 @ 2 ohms
or 1500x2 @ 2 ohms
u now what i mean or is getting two separate amps for each sub better
Username: Juliob
Santo DomingoDominican Re...
Post Number: 238
well that's hard for a two channel amp but if you're gonna power subs then get viper 2500 from ikesound
Post Number: 58
thanks
Username: Tjmutlow
Post Number: 1721
well, it won't matter what powerfull amp you put in unless you upgrade charging system. it is a decent amp
Username: Fiber
Post Number: 105
not a bad amp but you can get it alot cheaper then that... ebay
Username: Terry6405
Sullivan, IN US
Post Number: 585
get 2 nine.1's and strap them together. 2400 watts rms at 2ohms rated at 12.5 watts
use this code and get then for 315 each shipped!!!
EDB91
(coupon for edaudio.com only)
look here
http://edesignaudio.com/product.php?cid=4&pid=6&cur=USD
Username: Juliob
Post Number: 242
that's a sweet deal, but i don't know if he's willing to spend 600+ on amps, and he'll need an alternator for sure, so i say tat go with the viper and buy an HO alternator
