2 ohm stereo
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 334
ok quick question... my amp is 2 ohm stereo stable....
so would this mean i can hook up 2 2Ohm subs making a 4 ohm load
or that hooking up 2 4Ohm subs would bring it to 2 ohms.....
Username: Awm44444
Post Number: 62
you can hook up one 2 ohm sub to each channel of the amp which means you will hav 2 2 ohm subs. if u had one sub u could bridge it and wire it to the amp for a 4 ohm load
Username: Sw9152
Post Number: 161
a 2 channel amp is basically 2 amps in one package. if you hooked a 2 ohm load to each channel it would be 2 2ohm subs making a 2 ohm load per channel. if your amp was mono channel amp it would be a different story...
