Hd. unit loses memory
Username: Tysonb
can somebody please explain why all the head units i install in my 87 civic lose their memory when turned off. cheers
Username: Illuminator
Post Number: 2775
There is no power being constantly supplied to the battery constant wire (yellow) on the head unit when the car is off.
Username: Tysonb
is their a way to fix this?
Post Number: 2777
Run a wire directly from the positive battery terminal up to the head unit. You might also be able to tap into a fuse-just make sure the fuse still provides power when the car is off.
