Need help on getting a system
Username: Viva_la_bam
Post Number: 19
i have a chrysler 300c 2005 i want a sood system i was thinking of getting 2 12 w7 with a jl audio 1000/1 amp would that sound good
my budget is 4000
Username: Sw9152
Post Number: 124
umm.... yeah that would sound good. get some component speakers and a 4 channel amp to balance the sound. a HO alt. would help the strain on the electrical system.
Username: Matt12490
Benicia, California USA
Post Number: 433
that sounds good, i would go with 2 of those 1000/1 's
Post Number: 20
ported or sealed
Username: Sw9152
Post Number: 129
ported=louder more boomy
sealed=tighter more crisp
Username: Blkwardog
hey im jus startin out as well and hav been doin a lot of lookn around and i was wondering wut u guyz think bout either Image dynamics id max, JL w6v2, and kicker solobaric l7. any other suggestions would b great too. im lookn to get a pair and not get the pair much more than 600$ in cost. thanx all
Username: Shman
Michigan United States
idk how the kicker L7's compare to the idmax or JL's, but i do know that 2 12"L7's are a lot cheaper than the others, and would sound excellent in a ported box. also i would look at kicker cvx's. even though their more expensive, i hear that the sq is a lot better... ascendant audio arsenal 12's are sweet too, also $440 for 2
Username: Shman
i also think that it would be ridiculously sweet to have a $4000 budget.... just sayin'
Username: Delsole
Post Number: 155
o it sure would be
Los Angeles, CA USA
Post Number: 3174
viva la bam.....the chrysler 300 is my favorite car. do you have some nice 22" rims on those? if not you should get it. they look soooooo tight with the deuces. also why not get the 2 13w7s with 2 jl audio 1000/1. you should have plenty of space in your trunk.
Username: Delsole
Post Number: 156
think of the possibilities
Username: Blkwardog
thanks for the imput archie, iv heard ppl say that kicker isnt a good brand for subs cuz they lack sound quality and thats the main thing i need..but i keep my options open and il go look at the ascendant audio's
ps wayne from bfore
