Havoc in this??
Username: Talon_es93
Post Number: 57
would a havoc be good in this car?Upload
Username: Extremesound1
Coventry, RI United states
Post Number: 34
clean it up a little or should i say alot ,,,,,i mean you got to match the quality of the subwoofer to the quality of your car LOL. yeah havoc would look good in anything
Post Number: 59
i'm changin the egine right now so uk... when its runnin its never durty and it's gunna get painted again so it'll be ok..later on today imma put some coil overs on it and slam it about 3 inchesw maybe 4...and i have 2 different sets of 18s for it so it'll be ok once its fixed uk....but about the sound in the car.... that havoc won't be to much?
Username: Gavbo211
US
Post Number: 187
depends on how much u consider too much lol most any decent subwoofer will slam in a hatch back.. my w3v2s in my camaro are rediculous and they are only 10's. and a havoc will be louder than just any old sub. if i was u id go for it. should be awesome..
Username: Young_james
Post Number: 1029
should get really loud in that car
PS - don't forget about that dent on the back! lol
Username: Rovin
Trinidad & T...
Post Number: 6758
not familiar with that car but i'm guessing a 15" sub will be too big in there & maybe a pair of 12s just might fit in good ........
Username: Lexuscoop
Post Number: 1299
thats a saturn right? if you move the amp around and get rid of the tire things, like make the box around them im sure you could easily get 2 15's in there
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1445
i think thats a eagle talon, my friend has one with one 15 L7 ported, so i know 1 15can fit.
Post Number: 68
i've had 2 12s and 1 15 in there before... and 5 10s and also 4 12s.... but if a 15 is to big for a good box and air space and all that then i'll go with 2 solo-baric L7s or 4 CVRs
Post Number: 69
like i said imma repaint it so all the dents and all that will be gone
