What do you think of this sub/amp combo?
Username: Sweatyogre
PA USA
Bazooka Bass Package
Would this be a good deal to put in my 94 Explorer?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6161
nope
PA USA
What about this Visonik Bass Package?
Post Number: 6162
nope
Post Number: 6163
whats ur budget
PA USA
Not very much. Max I wanted to spend for the amp/sub(s) is $250.
Username: Young_james
Post Number: 1025
you could pick up a a8000T on e-bay, and 2 infinity 1240 subs for about 250-300. Just build your own box for em. Infinity subs get pretty loud and sound excellent too. WAY better than the bazooka and Visonik package.
Username: Sw9152
Michigan
Post Number: 220
or a a8002t and this
http://cgi.ebay.com/Pair-ALPINE-SWS-1242D-12-DVC-4OHM-SUBS-BRAND-NEW_W0QQitemZ58 80234520QQcategoryZ18803QQrdZ1QQcmdZViewItem
or
http://cgi.ebay.com/2-Kicker-CVR12-2005-Comp-VR-Subwoofers-12-NEW-CVR-800W_W0QQi temZ9701280269QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or a couple of these
http://cgi.ebay.com/NEW-12-ECLIPSE-SUBWOOFER-SPEAKER-CAR-AUDIO-SW6123-4_W0QQitem Z5881751116QQcategoryZ18803QQcmdZViewItem
Username: Sw9152
Michigan
Post Number: 221
oops read your price range wrong. a a8000t and this sub, just turn sensitivity and bass boost down because you will be overpowering it a little.
PA USA
I can definately build my own enclosure, the only reason I liked the Visonik is because I thought it was a pretty good deal. Thanks for the advice and links, I'll definately look them over. So you guys are saying Audiobahn A8000T is my best bet for a cheap, but still decent quality amp?
PA USA
What if I put an Audiobahn A8000T 800W with a INFINITY Reference 1240W 12? The amps RMS wattage is 800 and the speakers reccomended is 300, but it's max is 1000W. Would it be alright to put them together?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 236
just turn the gain a lil down or you can test it by yourself, if the subs handles 400w then you leave it that way, if you see that the sub starts missing notes or doing some weird noise then you turn the gain down
PA USA
Post Number: 7
I mean only hooking one up to it. I know if I hooked two up to it, they'd split the wattage and be handling 400 apiece, but what if I tried to have one of those 12s handling 800 watts?
Username: Rustysurfer916
i got 2 kicker compVR subs on ebay for about 160 shipped. and i built the box and those things are more than enough bass for anybody. if you want more bass than what they put out then your just tryin to show off. but im not saying theirs anything wrong with that. i would like to.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 710
comp VRs are a good choice for the price.
