New member Username: Ajdavies91Michigan USA Post Number: 1 Registered: Mar-06 | I'm new to this so PLEASE HELP!! I have a set of Infinity Perfect 5.1's and when i turn on my radio they buzz for few seconds but eventually it goes away. The buzz lasts longer when it is colder outside. It makes this sound when the car is not running also. I was thinking a bad ground but i checked and cleaned the amp and HU's and they all seem good. The rear speakers (572.5cf) don't do this at all. And the power wire runs down the other side of the car away from the RCA's. The birth certificate rates the amp at 117wrms@4ohms. I'm puzzled... The system : HU -Blaupunkt San Francisco CD70 Amp - Blaupunkt PA4100 I know I shouldn't have bought Blaupunkt but I was clueless at the time Thanks in advance, Andrew |
New member Username: Ajdavies91Michigan USA Post Number: 2 Registered: Mar-06 | Well upon further searching on the internet I found the problem. My problem is the capacitor charge up noise. So I guess I'll have to live with the noise cause I'm sure it's not worth the money to send it to Blaupunkt for repair. http://www.carreview.com/cat/car-audio/amplifiers/blaupunkt/PRD_97398_1806crx.as px |
